Installed a FS20Z-1 in a WET wiring configuration to control an standard plug outlet (pool pump). The problem is, the FS20Z-1 when turned off only stays off for a few seconds. It is working like a dry contact sensor for a garage door. I changed the device handler “Type” to “Z-Wave Switch,” but get the same results. Any thoughts what I need to do?
Thanks!!
Assuming it does the same thing when you press the manual button on the device, you’ll probably get the quickest answer if you contact gocontrol support. It could be a wiring issue, it could be a defective device, but they should be able to walk you through the troubleshooting in the most efficient manner.
http://www.gocontrol.com/support.php
http://www.gocontrol.com/manuals/FS20Z-1-Install.pdf
