Hello everyone,
I live in the Netherlands. I am trying to integrate a Frient EMI2 P1 meter with SmartThings, but I am getting completely unrealistic measurements and I am not sure whether this is a driver issue or something else.
My setup:
Samsung Frame TV
Samsung SmartThings Hub Dongle VG-STDB10A
Frient EMI2 P1 Meter
Landis+Gyr smart meter (DSMR 5.0.2)
SmartThings Edge driver: “Zigbee Power/Meter” (Developer: SmartThings)
The EMI2 is detected successfully and appears online in SmartThings. The Zigbee connection is stable and the device is communicating with the hub.
However, the reported values are clearly incorrect:
Voltage: 65.5 kV
Current: 65.5 kA
Power per phase: around -32.8 kW
Total power: around -8.4 GW
The LED on the EMI2 is continuously blinking red.
I have already:
Removed and re-added the device multiple times
Reset the EMI2 multiple times
Re-paired the SmartThings Hub
Added a Zigbee router (Philips Hue Smart Plug connected to SmartThings) between the hub and the meter
Confirmed that the smart meter is a Landis+Gyr DSMR 5.0.2 meter
The device is currently assigned to the SmartThings “Zigbee Power/Meter” driver.
My questions:
Is the EMI2 supposed to use a dedicated Frient Edge driver instead of the generic SmartThings Zigbee Power/Meter driver?
Has anyone successfully connected a Frient EMI2 to a Samsung SmartThings Hub Dongle VG-STDB10A?
Could the incorrect values indicate that the device is being interpreted by the wrong driver?
Does the continuously blinking red LED indicate a known issue?
Any help would be greatly appreciated, as I have been troubleshooting this for more than a week now.
Thank you!
