Dacor DRR3098RAP, once connected it shows up, see screenshot, but switching between on and off doesnt do anything, a shame. Would love to have this.
Thanks @Jacob_Freund , and welcome!
I checked the logs on my side: your Refrigerator accepted the commands, and its Sabbath mode status changed within a fraction of a second each time you toggled the switch, so the connection itself is working.
A few questions to narrow it down:
- What did you expect to see change? On many models Sabbath mode only shows when you open the door (interior lights stay off) or as an icon on the control panel.
- Could you turn the Shabbat Switch on, wait a minute, then open the refrigerator door and check whether the light comes on?
- Note that only the Refrigerator column is linked. Your Freezer is a separate device, and the integration currently controls one unit per install.
Let me know what you see!
Turn Sabbath mode on and off automatically, plus lights and thermostats (free until November 22)
Since Sabbath mode still isn’t available in Routines, I built an app that does it for you.
Hazman (hazman.app) connects to your SmartThings account and runs everything on Shabbos and Yom Tov times for your address:
- Fridges: turns Shabbos (Sabbath) mode on before candle lighting and off after Havdalah, on Samsung fridges that offer Sabbath mode to SmartThings. We’ve tested it on several Samsung models.
- Lights: on/off schedules based on zmanim, such as “on at Shkiya, off 3 hours later”, with different times for Friday night and Shabbos day. It works with any light, switch or plug in SmartThings. We’ve tested Kasa, Leviton and Lutron.
- Thermostats: sets heat or cool before Shabbos and sets it back afterwards. We’ve tested Honeywell Home and Sensi.
- Yom Tov, two-day Yom Tov and Shabbos/Yom Tov combinations are handled automatically.
- You can share your home with family members, and there are quick buttons for one-time changes.
Some fridges, including some Dacor units, list Sabbath mode but don’t actually let apps turn it on. If yours is one of them, Hazman will tell you when you test it.
It’s free until November 22. If you try it, I’d love to hear your fridge model and whether it worked.
(Disclosure: I’m the developer of Hazman.)
Welcome, and nice to see more options for the community!
For anyone reading: the Shabbat Switch integration in this thread remains completely free, with no trial period. Besides fridge Sabbath mode (it only shows fridges that actually support it, and verifies each Shabbat that the fridge really switched), the Shabbat Switch itself is a regular SmartThings device, so you can use it in Routines to control any lights, plugs, thermostats or other devices automatically for Shabbat and Yom Tov.
Shabbat Shalom!
Interesting, I waited 2-3 minutes. In fact I’m going to leave the switch on on for a few hours. The lights still come on.
Thanks @Jacob_Freund , that’s really helpful. I checked on my side, and your fridge’s connection to the integration has dropped since your earlier tests, so this latest test didn’t actually reach the fridge. Sorry about that, it’s a bug on my side that I’m fixing.
Could you try once more?
- Remove the Shabbat Switch integration in the SmartThings app.
- Reinstall from the link here: GitHub - dotanshai/SmartThings: My SmartThing Deivce Handler · GitHub
- On the fridge selection page, tap the new Test button next to your Refrigerator. It takes about 15 seconds and reports whether the fridge actually entered Sabbath mode.
- Then turn the Shabbat Switch on and open the door to check the light.
If the test passes but the light still comes on, that would confirm what another Dacor owner here found: the fridge reports Sabbath mode as on but doesn’t actually apply it, which is a Samsung/Dacor firmware limitation I can’t work around.
Hi @EM1 , welcome! Here’s the install link:
A few tips:
- Open it on the phone with the SmartThings app installed.
- Make sure your SmartThings location has an address set (Location settings), since that’s how the Shabbat times are calculated.
- If you have a Samsung fridge, you can select it during setup and tap Test to check whether it supports Sabbath mode.
Invite links expire periodically. The current one is always here: GitHub - dotanshai/SmartThings: My SmartThing Deivce Handler · GitHub
Let me know how it goes, especially your fridge model if you have one!
Really, thank you so much for this. I’ve been looking for an automated solution ever since I forgot to set the Shabbos mode.
I was able to follow the link and select the location - and then set the times for candle lighting and havdalah - but then when I then authorize ““Shabbat Schema Location Lookup” to access these things” - I receive the following error:
ST token exchange failed: {"error":"invalid_grant","error_description":"Invalid authorization code"}
Seems the app limit of 20 has been reached:
i just got a fridge and found out it had wifi and could turn shabbos mode on with my phone was playing with chatgpt for a couple hours trying to automate it then came to a road block that it would cost $5 a month for a token chatgpt eventually led me here this is awesome but failed like zev my model is samsung RF29BB8600QL would really love your help getting this to work
Quick update: between Nov 10–12 installation failed for some of you (errors like “ST token exchange failed / Invalid authorization code” or “Unknown or expired authorization”). This was caused by a SmartThings install limit plus a page-reload issue, and both are fixed now. If you tried during that time, please try again with the same link:
@EM1 this should work for you now too. Sorry for the trouble!
this worked for me now thank you so much tizku lemitzvos a couple questions
is there a way to see this somewhere that its connected
also is it set up for yom tov
will this work indefinitly or do i need to be concern it will stop at some point without notice
