Delete the device again and add it again , try neer your hub . You can also try to reboot your hub .
Thanks I have deleted & re added over 20 times still having issues. Also standing right next to the Smartthings hub. Ive rebooted the hub aswell.
Update managed to get it working. By pressing buttons marked 2 & 4 while in paring mode??
Hope ok to post but finally got mine working so thought I would upload a video as to what I did to get it working.
Hello guys, i have got a single button of this device and it works perfectly. I am using it for unlocking the door when i am home but there is an issue. When i am out of home the battery drains very fast and after a couple hours it goes completely empty. What could be the problem?
A huge thanks for these recent instructions. I tried setting up a Moes 4-switch device last year with no luck, but the new device handler and video from @P_Will made set up a breeze this time!
I saw in the DHT thereās an option to use reverse button order but I canāt seem to make this work. Do I just need to modify line 104 to:
input name: "reverseButton", type: "bool", title: "Reverse button order", defaultValue: true, required: true
Can I just modify my existing handler and re-add the device, or do I need to remove everything and start again with the correct code modifications?
The option for reversing the buttons order is available from the mobile app :
Press the 3 dots at the upper right corner of the device details screen :
Then switch the āReverse button orderā option
Ah! I would never have found that there - thank you!
The only thing that doesnāt seem to work for me is the battery status, shows a 0% with a little red dot - might just be that my Moes model isnāt fully supported by by this device handler, but the main thing is the buttons work.
Hey guys, could you please add the following FP to the driver?
ZEMISMART 1 Channel Tuya Zigbee Button model: TS0041
Hi, @Trakker2
A few weeks ago I was able to translate the Zigbee configuration commands into ST Edge Lua and it works properly in a MOES TS004F, but I was wonderingā¦ is it possible that these steps are applicable for rebranded TS004F or even the 3-Button model (TS0043 model if Iām correct)?
For reference, I mean these steps you shared with us:
And also, for everyone here, Iād really appreciate it if you could test the driver I developed for this device. A community member confirmed at this thread that it works ok with a not-even-branded TS004F, so I was hoping to get some feedback from you if possible
So, Iāll leave my channels below = )
- Main channel: @erickv Shared Drivers
- Dev channel: dev-@erickv Shared Drivers
Hi @erickv ,
I can confirm that your Edge driver works OK with TS004F scene switch! Good job!
I installed the Lua driver from your channel, then removed the device that was using the old Groovy DHT, removed the battery, waited 5 minutes, paired it again, āButton-battery-v.1.0.1ā driver was assigned. Created a simple routine to control an Edge controlled bulb - and the long-awaited āHomeā icon is there!
I will further comment on your thread, congratulations again!
Hi guys, I have connected this 4 scene button to ST https://smile.amazon.co.uk/yagusmart-Wireless-Switch-Battery-Control/dp/B08J3TMGJH/ref=pd_day0_1/262-6377440-9452037?pd_rd_w=43eLE&pf_rd_p=8ec13b8a-30d2-48fc-8503-84c56766370d&pf_rd_r=HMN5HZK7KWPE0WQRKHD1&pd_rd_r=00979419-e099-4b91-835c-87cd1a588452&pd_rd_wg=qsAYo&pd_rd_i=B08J3TMGJH&psc=1
Connected like so:
However I am having one issue Home Assistant is only able to respond to the Button 1 event:
If I try to add 1/2/3/4 after Button nothing comes through but it does get logged on the API so it does work ok.
I tried adding - or _ between and no luck, it is not accepting any of the button numbers
Anyone know what name it is looking for maybe?
Hi new to Smartthings . if any of you still have your switches and hope to get it working. after i did a lot of reading all over the place i found that pulling the battery for a few mins , and after when you put it back all four buttons flash . this has effectivley factory reset it. then in front of my eyes turned from a thing to a 4 button control in the smartthings app. hope this helps someone . mine is the ts0044 by the way
Hey, iāve just tried it with my MOES 3 Gang zigbee and it works!
Thanks a lot!
This isnāt the MOES one and it doesnāt work with this device handler
Hey I just tried this with the moes 4 scene switch TS004F and Iām not sure what Iām doing wrong.
I have the device added to ST but it detects it as a switch (DH should be good as I have another of these switched added long time ago which still works)
I went to the IDE and select the Zemismart Button type and still shows as a switch but I did notice that the zigbee id and device network id were blank
Model seems to be: ESW-0ZAA-EU
