I’ve had a Fortrezz WV-01 water valve integrated and working fine with my SmartThings hub for years at our vacation home. I have “Arriving” and “Leaving” routines that include actions to open and close the valve. A few months ago the Leaving routine stopped closing the valve, so we started having to close the valve through the Things menu. The Arriving routine still opens the valve as before.
Finally having some time to look into the issue, I first created two new routines called “OpenRoutine” and “CloseRoutine” that only have a single action in them; to open or close the valve.
Looking at the Live Log for the valve in the IDE what I’m seeing is that opening and closing the valve from the Things menu sends a command like this for both an open action and a close action:
trace zw device: 06, command: 2201, payload: 00 00
If the valve is closed and I run the “OpenRoutine” I again see the same command in the log:
If the valve is open and I run the “CloseRoutine” I see nothing in the log.
Occasionally I’ll see one of these two commands in the log, but I haven’t figured out what they are or what triggered them:
zw device: 06, command: 2003, payload: FF
zw device: 06, command: 2003, payload: 00
Fortunately Smart Home Monitor is still able to close the valve when a leak sensor is triggered.
Does anyone have any idea why a routine fails to close the valve?
