I have two Fortrezz water meters and one is stuck at 3 gph. The other meter is stuck at 2.4 gph but will increase. At zero flow it goes back to 2.4 gph?? I did download a new device handle about two years ago. I was looking for some way to do a reset without removing it from hub. Any help would be greatly appreciated. thanks. “EDIT” Please disregard this post, I figured it out. Thank you Johnconstantelo for your past help. I didnt follow your instructions correctly the first time. I went back, reread and performed it exactly this time. BINGO!! As a novice this technology can drive you nuts!!
Related topics
Topic | Replies | Views | Activity | |
Fortrezz Water Flow Meter Not Working | 4 | 785 | March 31, 2021 | |
Fortrezz watermeter? | 25 | 1769 | October 31, 2021 | |
FortrezZ Water Flow Meter | 553 | 25916 | August 15, 2023 | |
FortrezZ Water Meter DTH (redone for the new mobile app UI) (2021) | 10 | 1568 | June 9, 2022 | |
[Edge Driver] FortrezZ Water Meter (Updated 11/28/2023 see post #23) | 63 | 2519 | May 20, 2024 |
