Is my line 304 look ok ?
Well now I’m stumped…
Your time zone isn’t for the device, but the hub itself. Line 304 is right, and so is everything else. Very odd.
Try something for me?
Change your Custom ID in Device Preferences to “MAGDAFMI”
I’m wondering if there’s a length requirement for that value. Please try that, run water and look at your live logging again for me?
We’ll figure this out.
Wow, ok now we’re getting somewhere. You should have these 3:
I would definitely contact support because those are important. If you try to use any SmartApp using that (like Smart Lighting and sunrise/sunset parameters) it won’t work.
I’ll search the Community and other sources to see what I can find.
Check this out:
Try adjusting your geofence in the ST mobile app to make it a little bigger or smaller, and then tap on Save. After a minute or two, check the IDE and see if those settings show up?
After change Custom ID to MAGDAFMI same
3:23:46 PM: error java.lang.NullPointerException @line 304 (zwaveEvent)
OK, no problem. Check my post right above this one. I bet your geofence needs tweaked so it registers the location correctly.
I have iPhone and don’t see any geofence adjusting in ST app
Do this:
- Tap on More in the lower right hand corner of the app.
- Next, tap on the gear in the upper right corner.
- Now you’ll see the geofence settings. Tap on that and set your range.
- Tap on Save.
Ok I did play with location and now I have Time zone and Weather
Now let’s check your live logs when you run water.
Is all working !!! HUUUra
Outstanding!
Thank you
That stupid location on the map I will never go there to change anything so wired for me
THANK YOU
No problem at all!
When you change Reporting Rate or High Flow Rate, and for some reason they don’t change after you tap on Save in Device Preferences, tapping on Configure Device forces another attempt at changing those values.
Technically that tile isn’t needed, but I keep it there just in case.
Thank you again I do not know how that location change itself because old app was working for about 6 months and stop showing graphs but still showed flow
Thank you are THE BEST helper ever I know
Thanks, and you are very welcome!
