R2D2
1
I’ve integrated IFTTT with Nest and SmartThings, which shows interfacing of my Lightify bulbs.
Is there a way to flash the Lightify bulbs though via IFTTT, currently I can only see to switch on or off.
This could be handy for nest smoke alarm, SHM alarm, amongst other things.
How about this:
Firstly, create a momentary switch in ST.
Then, use IFTTT to turn on the momentary switch when the nest smoke alarm is triggered.
Then, using the CoRE Smartapp, create a piston that, when that momentary switch is triggered, flash your Lightify bulbs.
Another option would be to use the Nest Manager smartapp and create a CoRE piston which, when the nest smoke detector goes off, flashes the lights.
