Mike, check this out:
soonā¦the same way they promise resolution to all the support ticketsā¦soonā¦i have some open a year or more and they keep saying soon. they either hope i forget or they later say they have more important things to do or they promise the next update will fix the issue. unfortunately, ST is more of a hobby than a reliable smart home. promises promises
Probably right when I get home from work, sunset routines are firing and I actually need it operationalā¦
I donāt use setlevel via smart Lighting in any of my automations, my issue is that Iāve never been able to change the icons for dimmersā¦
Still no update here. Still showing 14.00008. No info shared from Smartthing on if they are finished or delayed.
Update window is from from 9 am-12 pm PTā¦ Sounds like things are right on time to me if some users have received the update. I just got mine a few min agoā¦ chill out.
I be chilling but curious. 12 PM PT would be 2 PM CT and it now 3:27 PM CT here. Just saying.
14.8???, how did you end up with some bastard interim version?, official production release was 13.13 AFAIK.
BTW, I have the update, and notice no difference.
Today was first time I have checked version, and it showed it was updates 10-22 to version 14.00008. Maybe it was in response to a support ticket. If it was it did not fix the problem.
Mine was 14.8 before the updateā¦ Maybe itās time zone? Maybe thatās the reason that the bugs seem so random, there are different hub versions out there not being updated?
Mine is still 000.013.00013 shouldnāt it be updated by now??
That is a Hub V1 firmware version number. I highly suspect this update only affects Hub V2.
Any idea what the improvements are for SHM?
My Hub has been updated, just checked:
hubcoreVersion: 000.014.00013
Donāt everyone loose hope!
Most likely a long rolling update.
Can anyone confirm that v1 hubs will receive the update? Or is this just a v2 fix?
Still waiting patiently here on the east coastā¦14.00008
I checked the firmware version when I came back from work and its installed, but I noticed that my Nest Thermostat integration is not working well anymore: it looks like I cant send it commands to control it although I can still get the current live status from it.
Anyone else having problems with their Nest integration?
Same problem with Nest.
Try rebooting your hub.
Issue with Nest started before the firmware update.
There is a solution that worked for me:
