I was able to run the revised script although it still did not remove the Ads. Any other ideas?
Thanks,
Victor
Thanks,
Victor
Hey @aron7676, thanks for the setup script! I just got 3 Amazon Fire OS 5.4.0.1. Your utility generally worked very well. I saw three issues that I thought youâd appreciate knowing about:
Step 2 errored out. I assume this is because I bought the Fires âwithout special offersâ (Amazon speak for âdoesnât include ads on lock screenâ, which you get to pay ~$20 for the privilege of not having the ads). If I had not paid the $20, wonder if your utility would have done the trick?
I couldnât tell if Step 1 (blocking updates and removing Amazon OTA) actually worked. Is there a way for me to verify this?
Lots of errors on Step 3 (and not just the error messages that were noted as acceptable). Is there a way for me to know which apps I donât need (or, if easier, which apps I do need) on the Fire if all Iâm using it for is as a ActionTiles/Fully browser for ST? I assume I can somehow delete the bloatware manually (Iâm a Fire noob).
Let me know your thoughts. And, again, thanks for the awesome utility!
Iâm having a problem with Step 6 on this⊠After installing the Launcher Hijacker, it asks me to select Nova Launcher, and press OK.
I do that, but thereâs no feedback on the device, or the script, so I just press okay and continue.
After, there doesnât seem to be any Launcher configured on the Fire, so I just have an empty screen with only Google and Chrome on the menu. Iâve no access to any of the apps, because there are no other icons on the screen
EDIT: I managed to get back into the HiJacker, and swap the Launcher back to the Fire Launcher⊠I can see the apps on the home screen, which lets me then configure LANNouncer, but when I tried to open Nova Launcher, it just flashes black once and does nothing
Nevermind⊠Didnât have ADB enabled properly
I received a device with the right software to use the script and it has all worked. Iâve just unlocked it and I was forced to set a pin as there are kids profiles on my amazon account. To stop it being used it says I need to hide them or similar, but the settings for this doesnât work, i assume as the software needed has been removed by the scripts. Any ideas on ways around this?
thanks,
Once youâve run the script, I would avoid even signing into an Amazon account. Itâs just going to cause complications.
Youâre best bet might be to factory reset and re-run the scripts.
I didnât think I did; I had no choice to enter my password to get back in to the device. I wonder if they pre-registered it. I might try deregistering it first to see if this saves setup again.
Taking this a step farther, ive installed automate-IT and smartthings since the play store is on it. on my non Fire OS devices, ST sends a notification that automateIT sees and opens an app or a webpage, or whatever. The problem, though, is the Fire tab doesnt get notifications from ST. ive made sure the notifications arent blocked and every other non fire OS device gets the push notifications, but none of my fire tabs do. is there any way to get notifications or any adjustment that can be made on the script that would allow notifications to come through? I feel like there is something in the OS blocking the notifications but i cant figure out what - its not the notification settings.
I ran into the same issue. For what I wanted to do, I worked around it by configuring an IFTTT applet to send a notification and then have AutomateIT pick up the notification from IFTTT rather than SmartThings.
ok thats a good idea. little more work but if it does the trick its good enough for me. no issues getting IFTTT notifications with a fire tablets?
Itâs working for me.
awesome. im going to test it today. Thanks for the idea!
I have the same problem, they used to work just fine and then one day they stopped and never came back. Pretty sure this happened after the tablet was updated to the most recent build. Not sure if it is an ST app issue or a fire tablet issue.
i dont get it. i cant get notifications from IFTTT or stringify in fire OS either. maybe a factory reset is next and ill start over.
Any tips how steps 1-3 can be done for a new Fire 7 tablet 5.6.0.0?
I saw that the stock apps would not be removable, but I seem to be unable to remove the OTA updates, and Lockscreen Ads
Did you extract the zip file? It wonât work unless you extract it.
Extracted, ran .bat file, selected e but canât find device
Did you ever do a reset, interested to know if it fixed the issue. The only app I get notifications from on the fire tablet is the Ring doorbell app.
No, I havenât had as much free time as I expected. With any luck Iâll get to mess with it this weekend.
I did using VMWare but it took time to get the tablet to be seen and to get the drivers to load.
