Hi all
I bought the Fibaro Z Wave Universal Sensor, which can be seen here, which can be found and connect tot the Hub (once powered by a 9v DC power supply/ battery), but then will not allow me to control any of the outputs (which there are 2).
I wanted to use this sensor to control a garage door and gates, as the preferred solution from ST is a Z Wave device that will not work in the UK or EU.
Can anyone help (advise, code, or suggestions)?
