The Sensor 2 seems to work out the box with the ZW5 handler with the exception that the colours do not seem to change with temperature. I do not have the older versions of the sensor so cannot confirm if it works ok with other sensor versions.
Also and more importantly (as James @Townsmcp asked above) is it please possible to change he main tile and to display OPEN/CLOSED in the list of Things against the sensor. As this is the primary function of the sensor I personally feel that this is the info that should be displayed. If you and others feel it is important to show the temperature in the list then how about putting the temp value in a Green or Red box to show if the contact is Open/Closed. I am still getting to grips with the code but making such a change is way above my knowledge yet. Would also be great to add config parameters to the DH so we can make parameter changes from within the app itself.
Unfortunately without displaying Open/Closed in the list I cannot really use the DH as I rely on the list values as I scan down my list of things. Any guidance or help in making the changes are appreciated if you do not have the time to do so yourself.
Finally and I apologise for all the requests, would it be possible for you to add git hub integration to your repository please. Not sure if there are any other necessary steps required but putting the DHâs in a folder named âdevicetypesâ may be enough.
Thanks again for all your efforts.
