I have recently aquired some of the very nice Fibaro Wall Plugs.
The one thing missing, was the amount of money im burning with Energy.
After trying several different device handlers from this forum, i found that none of them work for me at all. So i decided to make a new device handler that works on my Android phone.
I used a lot of inspirtation and learning from the other examples and i wanted to share the Code with you to try it out
(I do not have GitHub Account yet, so i just post the code here. Let me know if this is in any way problematic.)
metadata {
// Automatically generated. Make future change here.
definition (name: "Fibaro Wall Plug with Costs") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Power Meter"
capability "Polling"
capability "Refresh"
capability "Configuration"
capability "Sensor"
attribute "energyCost", "string"
command "reset"
fingerprint inClusters: "0x25,0x32"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 10000; i += 1000) {
status "power ${i} W": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
status "energyCost ${i} €": new physicalgraph.zwave.Zwave().meterV1.meterReport(
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("power", "device.power") {
state "default", label:'${currentValue} W'
valueTile("energy", "device.energy") {
state "default", label:'${currentValue} kWh'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat") {
state "default", label:'reset kWh', action:"reset"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("energyCost", "device.energyCost") {
state "default", label: '${currentValue}€'
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main (["switch","energyCost"])
details(["switch","power","energy","refresh","reset","energyCost"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x32: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
def newValue
if (cmd.scale == 0) {
createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh")
newValue = cmd.scaledMeterValue
BigDecimal costDecimal = newValue * 0.28 //Update number with Cost per kWh
createEvent(name: "energyCost", value: (String.format("%5.2f",costDecimal)))
} else if (cmd.scale == 2) {
createEvent(name: "power", value: cmd.scaledMeterValue, unit: "W")
} else if (cmd.scale == 1) {
createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "physical"
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "digital"
// Handles all Z-Wave commands we aren't interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV2.meterGet(scale: 0).format(),
zwave.meterV2.meterGet(scale: 2).format()
def refresh() {
delayBetween([
def reset() {
sendEvent(name: "energyCost", value: "Cost\n--", unit: "")
return [
zwave.meterV2.meterReset().format(),
def configure() {
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), // combined power in watts
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300).format(), // every 5 min
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), // combined energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 300).format(), // every 5 min
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 0).format(), // no third report
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 300).format() // every 5 min
