I bought my Fibaro Single Switch 2 a couple of months back and I also bought some 2 years ago (which are on different firmware). Recently the new one has stopped working as I think something has changed in ST. I remember initially when pairing it (as its a different firmware) I had some issue and now no matter what I do, it will not work. The other older ones work fine, just sometimes they show a delayed response.
After spending 3 hours yesterday standing in the kitchen trying to get this to work, I have got to the point that I donāt want to waste more of my life to trying to fix something that ST has broken, and I canāt even report it to support as when I email them to raise a ticket, I donāt get any response. So I think I will swap this Fibaro with a Zigbee Switch Module\controller as I need it for my underfloor heating and the replacement needs to take a high amp load, and winter is coming !
I have 3 Fibaro Single Switch 2 ZW5 that worked very well with Classic app but stopped working after migrations. It usually reports status (On/Off), often switches the light Off but never On. The light works well with momentary physical switch. No wiring has been changed - just migrated to new app.
I have been using your fixed DTH since you released it. I installed another Fibaro Single Switch 2 this week, and was really surprised that the problem reported in January is still not fixed. Almost a year, and no action from Samsung - I am so not impressed. It should also be made local!
Hey, all.
Thanks for the tips regarding the issue of Single Switch 2 not responding properly. I have just bought one with a date of 22nd November 2020 on the box and running firmware v3.03, and experiencing the same issue.
I canāt believe this is still a problem!!
Iāve switched to the Double Switch 2 and deleted the additional channel, and itās now working as expected.
This should be fixed, and should be made local as well! In my opinion, Samsung should remove their āWorks with SmartThingsā badge until this is done!
Iāve got to be honest, Iām pretty much done with Fibaro and will be looking at alternative providers for the future. I bought this single switch with the intention of using S2 for a 3 way switch set up (like you can do with the Dimmer 2), only to discover that S2 is just for sending scenes (which incidentally, has its own set of flaws). Their kit is way too expensive to have problems lasting as long as this.
Any suggestions for something similar (Dimmers and Switches) that work well with SmartThings?
