I noticed a flaw in the code. When I put that in the routine to close at night. It will try to close the shutter regardless of checking it’s current status. If it’s already closed it still try to close it again (which is triggering my alarms).
It would be nice it acts depends on the current status. Eg: if it’s already don’t excute close or vice versa.
@craigseymour i tested your modifications and after it i wasnt able anymore to set blinds at a certain %, even amazon echo answer “ok” if i ask her to set xxxx to x% but nothing happens, with original dth it works so i reverted back
@julbmann@cyberrage - sorry for the broken pull request and for the delay in getting back to you (been on hols for 2 weeks). It didn’t seem like the kind of change that would break stuff, and it works fine in the ST app and Google Home.
I’ve found our our old Amazon Echo Dot, so I’ll take a look and see what might be going wrong. That’s it though - I don’t have access to any other smart controllers
@Shiirrh - I’ll have a look at your request as well, although that’s a bigger change and may stretch my understanding of what needed to be done. The first change I made really just checks that a number is really a number, so nothing really too clever
I have test with my google home and the smatthings app and it work very good
I just can’t open or close partialy (50% for exemple) but i think it was the same before.
Thank you
@Shiirrh - Iadded some code which may fix the issue you reported - it stops the setLevel function doing anything if the level is already the same as that being requested. See post 108 for details on how to access it if you want to test it
And in fact I’ve realised what I’ve done won’t help you at all, because it doesn’t affect the open() or close() functions, just setLevel(). I’ll sort that out as soon as I can.
I created automation “good night” close all garage doors, Lock doors, etc.
But when I click that automation it’s opening/partial and closing it again for some reason. Even tho it is perfectly closed state already which makes my alarm siren to go off.
Hope that make sense. If you have any questions please let me know and I’m happy to send you few screenshot of my current settings.
Hi, first of all, tank you very much for all the work.
i tried your DH and its great but i notice that the S2 button from all the 4 roller shutters devices i have stop working, they’re all momentary switches pos. 0
Sorry for the late response. I was away for the bank holiday. I hope you had a good break too.
Anyway u fortunately it still doesn’t work. If you want I’m happy to upload my current settings (screenshots). Probably that will help you with finding the root cause.
Julien - huge thanks for the DTH for Fibaro roller shutter - it is the simplest to use from all I tested.
Instelled it and all seems to work with one issue - my blinds move only for 2 sec (either open or close) when I press the button up or down (same with physical buttons so it is a Fibaro issue not DTH). Than I need to press again and again and again. The courtain works when I pull it close or open - it goes all the way to begging or end however with wall switch control or app control it only moves 2 seconds at a time.
Have any of you seen this behavior?
Feels like changing some parameters may help - tried that but no luck till now - is there a way for me to read the parameters from the Fibaro?
