I have this installed and it is working. Wiring is off because I bought rgbw wires and realized I had rgb LEDs. So I just wired it up to test.
That link owns rgbw strips****
Shows
In the case of the LEDs I use, the RGB give better brightness.
In general LED strips usually come with 60 LEDs per meter, in the case of RGB strip all the LEDs are RGB…
in the RGBW strip that I use there’s 30 white LEDs and 30 RGB LEDs - so the brightness is less then 60 RGB LEDs per meter.
I think you should search for LED Strip with 120 LEDs per meter. this way you will get the most from both RGB and white LEDs.
Keep in mind, the grater the number of LEDs the stronger the power supply needs to be.
Gil
Hi, so i recently just got the UK hub v2 and wanted to know if i get the fibaro rgbw can i connect it straight to the ST hub? Also is there a instructions on how to wire it and connect?
