Does anyone know if there are cheaper versions of the Fibaro dimmers and relays( ie Chinese ) that can be used in the UK either behind the switch or near the pendant . £40+ a pop is expensive to do every switch
IKEA Tradfri bulbs could be an option. But then the switch would need to be in on position all the time.
I tried this, but couldn’t get the bulb to squeeze into the back box
I looked for alternatives but settled on Fibaro Dimmer 2. Vesternet has them down to under £41 at the moment too.
