The full code that i try to edit:
metadata {
definition (name: “Aeon Outlet”, namespace: “smartthings”, author: “SmartThings”) {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability “Sensor”
command "reset"
fingerprint deviceId: "0x1001", inClusters: "0x25,0x32,0x27,0x2C,0x2B,0x70,0x85,0x56,0x72,0x86", outClusters: "0x82"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV2.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("energy", "device.energy", decoration: "flat") {
state "default", label:'${currentValue} kWh'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat") {
state "default", label:'reset kWh', action:"reset"
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","energy","reset","refresh","configure"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x32: 2])
if (cmd) {
log.debug cmd
result = createEvent(zwaveEvent(cmd))
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv2.MeterReport cmd) {
if (cmd.scale == 0) {
[name: “energy”, value: cmd.scaledMeterValue, unit: “kWh”]
} else if (cmd.scale == 1) {
[name: “energy”, value: cmd.scaledMeterValue, unit: “kVAh”]
else {
[name: “power”, value: Math.round(cmd.scaledMeterValue), unit: “W”]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”
// Handles all Z-Wave commands we aren’t interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV2.meterGet().format()
def refresh() {
def reset() {
return [
zwave.meterV2.meterReset().format(),
def configure() {
delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 8).format(), // energy in kWh
//zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300).format(), // every 5 min
//zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 0).format(),
//zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 0).format(),
zwave.configurationV1.configurationSet(parameterNumber: 50, size: 1, scaledConfigurationValue: 1).format(),
zwave.configurationV1.configurationSet(parameterNumber: 51, size: 1, scaledConfigurationValue: 10).format(),
zwave.configurationV1.configurationSet(parameterNumber: 52, size: 2, scaledConfigurationValue: 1).format(),
zwave.configurationV1.configurationSet(parameterNumber: 53, size: 2, scaledConfigurationValue: 10).format(),
zwave.configurationV1.configurationSet(parameterNumber: 58, size: 2, scaledConfigurationValue: 10).format(),
zwave.configurationV1.configurationSet(parameterNumber: 59, size: 2, scaledConfigurationValue: 10).format()
