Hi All,
I have around 12 fibaro relays installed across my house. I’ve noticed a couple of issues and was wandering if anyone else has seen this behaviour behaviour
if the physical switch is toggled too quickly the relay doesn’t kick in, I.e Lights don’t turn on or off.
one of the relays (using the same device handler as all the others) doesn’t get its status updated in smart things when the physical switch is toggled. I’m using pollster as a temporary solution. But it’s odd it’s just the one
As a side note, I’ve tried numerous device handlers. Is there a “best” device handler ?
Cheers
D
