hi ive installed a fibaro dimmer module 2 on a one way lighting circuit , the bulb is a cfl under 25watts , i did the device handler code no probs and everything setup ok , So when i use the st app to turn off the lights the bulbs flashes constantly and when i try to use the actual light switch all it does is bring the dimmer range from 1 to 99 or whatever last setting was .
All i want it simple on/off functionality at the minute
