Hi Everyone,
I’m new to ST, but loving it greatly. I have a V3 hub, 4x mulitpurpose, 4x motion sensor, and also a Fibaro Dimmer 2 that I’m getting to know.
The Dimmer 2 is currently setup on a bench, using Live & Neutral connections to a dimmable LED gu10 lamp with a bypass inplace. The dimmer successfully performed a calibration on 1st powerup and all works fine via ST dashboard.
My question is, can I somehow dim below 1% as the lamp is a touch too bright for my intended use.Cheers
