Fibaro binary input (Dual contact and temperature sensor)
I could do we some help finishing a device handler I have tweaked. What I want to be able to do is have 2 seperate Contact sensers, which I have but I want to declare them as two separate “enums” so that I can use them seperatly in webCoRE. At the moment I have it working, but only if I then create 2 seperate virtual contact sensers and link them to the device.
Credit to @fuzzysb Stuart Buchanan for creating the original DH, thanks
If anyone know how to do this and could give me some help, would really appreciate it :).
 *  Device Type Definition File
 *  Device Type:		Fibaro Universal Sensor - Dual Contact + Temp
 *  File Name:			Fibaro Universal Sensor - Dual Contact + Temp.groovy
 *	Initial Release:	2016-01-17
 *	Author:				Stuart Buchanan
 *  Modified:   Steven Stroud 10-06-2017
 *  Copyright 2017 Steven S, based on original code by Stuart Buchanan with thanks
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Fibaro Universal Sensor - Dual Contact + Temp test", namespace: "Borristhecat", author: "Steven Stroud") {
    capability 	"Contact Sensor"
	capability 	"Temperature Measurement"
	capability 	"Configuration"
	capability 	"Sensor"
    command "updateCurrentParams"
    command "listCurrentParams"
        /* Capability notes
        0x30 Sensor Binary V1 V2
        0x60 Multi Channel V3
        0x85 Association V1 V2
        0x8E Multi Instance Association V1
        0x72 Manufacturer Specific V1 V2
        0x70 Configuration V1 V2
        0x86 Version V1
        0x7A Firmware Update Md V1 V2
        0xEF Mark V1
        0x2B Scene Activation V1
	fingerprint deviceId: "0x2001", inClusters: "0x20 0x30 0x31 0x60 0x85 0x8E 0x72 0x70 0x86 0x7A 0xEF 0x2B"
	simulator {
	tiles(scale: 2) {
      	multiAttributeTile(name: "thermostat", type:"thermostat", width:6, height:4) {
			tileAttribute("device.temperature", key:"PRIMARY_CONTROL", canChangeIcon: true, canChangeBackground: true){
            	attributeState "default", label:'${currentValue}°', unit:"C", backgroundColor:"#fab907", icon:"st.Weather.weather2"
			tileAttribute ("device.contact1", key: "SECONDARY_CONTROL") {
            	attributeState "open", label: '${name}'
				attributeState "closed", label: '${name}'
			tileAttribute ("device.contact2", key: "TERTIARY_CONTROL") {
       standardTile("contact1", "device.contact1", width: 2, height: 2) {
			state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
			state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
        standardTile("contact2", "device.contact2", width: 2, height: 2) {
    		state "open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e"
			state "closed", label:'${name}', icon:"st.contact.contact.closed", backgroundColor:"#79b821"
		standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2 ) {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
	main(["thermostat"])
	details(["thermostat", "contact1" ,"contact2", "configure"])
	def result = null
	def cmd = zwave.parse(description, [ 0x20: 1, 0x30: 1, 0x31: 2, 0x60: 3, 0x85: 2, 0x8E: 2, 0x72: 1, 0x70: 1, 0x86: 1, 0x7A: 1, 0xEF: 1, 0x2B: 1 ])
	if (cmd) {
		result = zwaveEvent(cmd)
	log.debug "parsed '$description' to result: ${result}"
	result
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv1.ManufacturerSpecificReport cmd) {
	log.debug("ManufacturerSpecificReport ${cmd.inspect()}")
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
	log.debug("ConfigurationReport ${cmd.inspect()}")
def configure() {
	log.debug "Updating Configuration of ${device.displayName}"
    def cmds = []
    cmds << zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
    cmds << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
    cmds << zwave.associationV2.associationRemove(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [20], parameterNumber: 10, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [60], parameterNumber: 11, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [8], parameterNumber: 12, size: 1).format()
	delayBetween(cmds, 500)
def createEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd, Map item1) {
	log.debug "manufacturerId:   ${cmd.manufacturerId}"
    log.debug "manufacturerName: ${cmd.manufacturerName}"
    log.debug "productId:        ${cmd.productId}"
    log.debug "productTypeId:    ${cmd.productTypeId}"
def createEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd, Map item1) {
    updateDataValue("applicationVersion", "${cmd.applicationVersion}")
    log.debug "applicationVersion:      ${cmd.applicationVersion}"
    log.debug "applicationSubVersion:   ${cmd.applicationSubVersion}"
    log.debug "zWaveLibraryType:        ${cmd.zWaveLibraryType}"
    log.debug "zWaveProtocolVersion:    ${cmd.zWaveProtocolVersion}"
    log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
	log.debug "BasicSet V1 ${cmd.inspect()}"
	if (cmd.value) {
	createEvent(name: "contact1", value: "open", descriptionText: "$device.displayName is open")
	} else {
	createEvent(name: "contact1", value: "closed", descriptionText: "$device.displayName is closed")
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd) {
    log.debug "Sensor Binary report"
	def map = [:]
	map.value = cmd.sensorValue ? "active" : "inactive"
	map.name = "motion"
	if (map.value == "active") {
		map.descriptionText = "$device.displayName detected motion"
	else {
		map.descriptionText = "$device.displayName motion has stopped"
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
	log.debug "Sensor MultiLevel Report"
	def map = [:]
	switch (cmd.sensorType) {
		case 1:
			// temperature
			def cmdScale = cmd.scale == 1 ? "F" : "C"
			map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision).toDouble().round(1)
            log.debug("tempvalue: " + map.value)
			map.unit = getTemperatureScale()
            log.debug("tempunit: " + map.unit)
			map.name = "temperature"
			break;
	createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
    log.debug "SensorMultilevelReport $cmd"
def createEvent(physicalgraph.zwave.commands.firmwareupdatemdv1.FirmwareMdReport cmd, Map item1) {
    log.debug "checksum:       ${cmd.checksum}"
    log.debug "firmwareId:     ${cmd.firmwareId}"
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
    	log.debug "ZWaveEvent V3 ${cmd.inspect()}"
	if (cmd.commandClass == 32) {
		if (cmd.parameter == [0]) {
			if (cmd.sourceEndPoint == 1) {
				return createEvent(name: "contact1", value: "closed", descriptionText: "$device.displayName is closed", isStateChange: true)
				log.debug "Contact1 is closed"
			else
			if (cmd.sourceEndPoint == 2) {
				return createEvent(name: "contact2", value: "closed", descriptionText: "$device.displayName is closed", isStateChange: true)
				log.debug "Contact2 is closed"
		if (cmd.parameter == [255]) {
				return createEvent(name: "contact1", value: "open", descriptionText: "$device.displayName is open", isStateChange: true)
				log.debug "Contact1 is open"
			else
				return createEvent(name: "contact2", value: "open", descriptionText: "$device.displayName is open", isStateChange: true)
				log.debug "Contact2 is open"
    } else {
		def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 2, 0x60: 3, 0x85: 2, 0x8E: 2, 0x72: 1, 0x70: 1, 0x86: 1, 0x7A: 1, 0xEF: 1, 0x2B: 1]) // can specify command class versions here like in zwave.parse
		log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")
		if (encapsulatedCommand) {
			return zwaveEvent(encapsulatedCommand)
def zwaveEvent(physicalgraph.zwave.Command cmd) {
	log.debug "Catchall reached for cmd: ${cmd.toString()}}"
def listCurrentParams() {
	log.debug "Listing of current parameter settings of ${device.displayName}"
    def cmds = []
	cmds << zwave.multiChannelAssociationV2.multiChannelAssociationGet(groupingIdentifier:2).format()
	cmds << zwave.associationV2.associationGet(groupingIdentifier: 3).format()
	cmds << zwave.associationV1.associationGet(groupingIdentifier: 1).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 1).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 2).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 3).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 4).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 5).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 6).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 7).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 10).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 11).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 12).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 13).format()
    cmds << zwave.configurationV1.configurationGet(parameterNumber: 14).format()
def updateCurrentParams() {
	log.debug "Updating current parameter settings of ${device.displayName}"
    def cmds = []
    cmds << zwave.configurationV1.configurationSet(configurationValue: [0, 0], parameterNumber: 1, size: 2).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [0, 0], parameterNumber: 2, size: 2).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [255], parameterNumber: 5, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [255], parameterNumber: 6, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [255], parameterNumber: 7, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [255], parameterNumber: 8, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 9, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [120], parameterNumber: 10, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [200], parameterNumber: 11, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 13, size: 1).format()
    cmds << zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 14, size: 1).format()
