FGS-222 problem
Hi all.
I use the devicehandler from [RELEASE] Fibaro FGS-222 Double Relay Device Handler (Also Philio PAN 02/04)
It works ok but not great for me.
I ask here because i think the problem is the devicehandler and not the webcore.
in the below the light is off but it says that it is on.
It seems that the FGS dosent sent the right status to the webcore, yet when i check the devíce in the ST app it updates ok
Received event [Sensor Vard Rum].motion = active with a delay of 66ms
+103ms ║RunTime Analysis CS > 18ms > PS > 62ms > PE > 22ms > CE
+105ms ║Runtime (36191 bytes) successfully initialized in 62ms (v0.2.101.20171227) (102ms)
+106ms ║╔Execution stage started
+114ms ║║Comparison (enum) active changes_to (string) active = true (0ms)
+115ms ║║Cancelling condition #4’s schedules…
+116ms ║║Condition #4 evaluated true (5ms)
+117ms ║║Cancelling condition #1’s schedules…
+117ms ║║Condition group #1 evaluated true (state changed) (7ms)
+119ms ║║Cancelling statement #2’s schedules…
+125ms ║║Skipped execution of physical command [hallbelysning OV].on([]) because it would make no change to the device. (3ms)
+125ms ║║Executed [hallbelysning OV].on (3ms)
+128ms ║╚Execution stage complete. (23ms)
+129ms ╚Event processed successfully (129ms)
Ty 4 the answer.
Were do i disable that?
Hopefully that fixes things, are you using the child device or the parent when you refer to it in the routine?
it worked. Ty all
