From an engineers point of view the text explaining what the house icon means is enough
However from a novices point of view it means this automation runs localy on the hub regardless of icon this is especially true if the automation has no icon visible anywhere, there is no context or placeholder in the automation description to show icon/no icon
The wording needs slight adjustment to remove any confusion
'If you see this icon above, the automation will run on your hub locally instead of the cloud…etc etc etc
This removes ambiguity and confusion for novices
Apologies for incorrect icon but I don’t have the ST version to insert
Without a reference point in the automation it means nothing to a novice, in fact I argue it could mean the automation DOES run locally, especially if the user has no knowledge of the icon, to them it’s just… a random bullet point icon
Then in an automation that does NOT run locally, should there not be a note indicating this automation uses cloud only
To be honest, I only found the text tonight, I had no idea it existed, I looked above in the automation, noticed no symbol and assumed the text meant it is only local if the symbol is present, as in list of automations where the symbol is also found
Either way I feel more clarity is needed all be it in a different place, in this instance it now appears in non local automations
Just trying to provide feedback to help the app become more novice friendly (or idiot proof) or universal (Mall)
