Feature Request: Nested ORs and ANDs in Routines
This is a feature request. I would like to see the ability to nest OR conditions for a few scenarios:
1.) I have multiple motion sensors in a larger room. I would like to turn on the lights if either of the motion sensors show movement.
2.) I have a porch light I created routines for based on motion from my Ring Doorbell. I would like to change that routine to turn the light onto full brightness IF the Ring Doorbell detects motion OR the front door is opened.
I am pretty sure the basic “AND” is there because you can request all conditions are met before the routine processes the action however, if you put in an “OR” I am sure someone is going to need the ability for multiple conditions to be true in one of those OR conditions.
If you choose 2 devices as triggers in routines, you can choose if ALL devices meet the specified condition or if ANY device meets the specified condition at the top of the 2 devices listed in the IF statement.
PERFECT!!! Thank you very much!!!
You can nest and/or by setting one or more device status as a precondition, then choosing “any” for the others. I’m sure there are particular cases where this isn’t the right combination but it should cover at least some.
