FAQ: Exact remote needed to reset Hue bulbs? (UK)
The Hue White bulbs can’t vary their color temperature that I’m aware of. Only the Hue color can do both RBG and White color temp. Maybe something is out in the UK though…
If Hue always uses the same endpoint, then this might work:
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Zigbee Hue White - HC", namespace: "smartthings", author: "SmartThings") {
		capability "Switch Level"
		capability "Actuator"
		capability "Switch"
		capability "Configuration"
		capability "Sensor"
		capability "Refresh"
		fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008", outClusters: "0019"
	// simulator metadata
	simulator {
		// status messages
		status "on": "on/off: 1"
		status "off": "on/off: 0"
		// reply messages
		reply "zcl on-off on": "on/off: 1"
		reply "zcl on-off off": "on/off: 0"
	// UI tile definitions
	tiles {
		standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
			state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
			state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
			state "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
			state "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
			state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
		controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 3, inactiveLabel: false) {
			state "level", action:"switch level.setLevel"
valueTile("level", "device.level", inactiveLabel: false, decoration: "flat") {
			state "level", label:'${currentValue} %', unit:"%", backgroundColor:"#ffffff"
		main "switch"
		details(["switch", "refresh", "level", "levelSliderControl"])
// Parse incoming device messages to generate events
	log.info description
	def msg = zigbee.parse(description)
	if (description?.startsWith("catchall:")) {
		log.trace msg
		if(description?.endsWith("0100") ||description?.endsWith("1001")) {
			def result = createEvent(name: "switch", value: "on")
			log.debug "Parse returned ${result?.descriptionText}"
			return result
		if(description?.endsWith("0000") || description?.endsWith("1000")) {
			def result = createEvent(name: "switch", value: "off")
	return result
	else {
		def name = description?.startsWith("on/off: ") ? "switch" : null
		def value = name == "switch" ? (description?.endsWith(" 1") ? "on" : "off") : null
		def result = createEvent(name: name, value: value)
		return result
   if (description?.startsWith("read attr")) {
		Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
			def nameAndValue = param.split(":")
			map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
		log.debug "Desc Map: $descMap"
		switch (descMap.cluster) {
			case "0008":
				log.debug description[-2..-1]
				def i = Math.round(convertHexToInt(descMap.value) / 256 * 100 )
				sendEvent( name: "level", value: i )
		sendEvent( name: "switch.setLevel", value: i) //added to help subscribers
		break
// Commands to device
def on() {
	log.debug "on()"
	sendEvent(name: "switch", value: "on")
	"st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}"
def off() {
	log.debug "off()"
	sendEvent(name: "switch", value: "off")
	"st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}"
def setLevel(value) {
	log.trace "setLevel($value)"
	def cmds = []
	if (value == 0) {
		cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}"
	else if (device.latestValue("switch") == "off") {
		cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}"
	sendEvent(name: "level", value: value)
	def level = hexString(Math.round(value * 255/100))
	cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 8 4 {${level} 1500}"
	//log.debug cmds
	cmds
def refresh() {
		"st wattr 0x${device.deviceNetworkId} 0x0B 6 0", "delay 200",
		"st wattr 0x${device.deviceNetworkId} 0x0B 8 0"
def configure() {
	log.debug "binding to switch and level control cluster"
		"zdo bind 0x${device.deviceNetworkId} 0x0B 1 6 {${device.zigbeeId}} {}", "delay 1000",
		"zdo bind 0x${device.deviceNetworkId} 0x0B 1 8 {${device.zigbeeId}} {}", "delay 500",
		//Switch Reporting
		"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
		"send 0x${device.deviceNetworkId} 0x0B 1", "delay 500",
		//Level Control Reporting
		"zcl global send-me-a-report 8 0 0x20 5 3600 {0010}", "delay 200",
private hex(value, width=2) {
	def s = new BigInteger(Math.round(value).toString()).toString(16)
	while (s.size() < width) {
		s = "0" + s
	s
private getEndpointId() {
	new BigInteger(device.endpointId, 16).toString()
