How does one get a list of all of the EDGE drivers they’ve enrolled to or installed on their hub?
go to the Details screen for the hub, click the 3 dots in the upper right of the screen, select Driver
If you don’t want to go device by device, you’re going to have to do it with the CLI using the smartthings edge:drivers:installed command.
You don’t need to. If you follow the suggestion of @jkp and go to the Menu --> Drivers
for the Hub device in ST, you can see the full list.
Yep, I see that now. When I first checked mine, my Driver menu pick was greyed out . . . not sure why.
Thanks all, found it!
I thought there was a way to do it through web interface too? Or just the app?
only the app at this point
