Fans that are variable speed motors should never be used with a dimmer, smart or dumb. You will burn out either the fan or the switch or both. See the community FAQ (the topic title is a clickable link).
You can usually use a regular on/off switch, again smart or dumb, with a variable speed motor, but then you don’t get speed control.
If you have a single speed fan, you can use a regular on/off switch, again smart or dumb, as long as it can handle the motor load.
Always check the specifications for any switch against the fan specifications to make sure they will match.
Never use a dimmer intended to control lights with a variable speed fan. The physics are different.
To control a variable speed fan, see the fan control FAQ. It mentions Alexa in the topic title but it applies whether you are using a voice assistant or not. ( The topic title is a clickable link)
