Failing Console Window
After some time developing any given SmartApp - published or not - the Console window starts to fail.
This is similar to Console not working
The problem I have is that it is not browser specific, and if I copy the code, delete the app and create a new app with the original code - it starts working again.
It’s almost like there is a memory leak or something like that preventing the console from displaying.
I can see the data in “Logs” - but it’s a pain switching between screens.
I noticed the same behavior, but I assumed it’s a problem with my code.
Debugging is a serious problem in the but when log is not working.
Yeah… I find it a little wonky as well. My experience has been that just refreshing the page returns normal operation (make sure your saved first)
I’ve tried that - it seems to be tied to the application - even changing browsers (or dumping cookies etc) doesn’t resurrect the Console.
I’m having a problem with console logging. It was running like a rock for weeks and today it started disappearing. I tried logging out, refreshing screen, dropped the app, started a new app from templates and its still not logging.
Any ideas are appreciated if you have a workaround!
