Hi,
I am working on Zigbee. I brought Philips Hue bulb and Philips Hue bridge. These two devices are using Zigbee ZLL spec. So i would like to capture the initial commissioning frames(inter-PAN) which are transmitted at 0db gain. I tried in different ways. I failed to capture those frames.
After many trails, i have some doubts,
While scanning from the Philips hue bridge using Hue App in mobile, after restore the factory settings, is it sends inter-PAN scan command or beacon request? because most of the time i observed beacon requests only. I didn’t seen any inter-PAN frames.
I tried even by changing the channels (11, 15, 20, 25). In every channel i observed only beacon request and some other encrypted frames. I was unable to capture the inter-PAN frames.
How these two devices are communicated? is it uses ZLL? If yes, how can i capture those inter-PAN frames?
And also i would like to capture the touch-link commissioning frames also.
When i press the restore factory setting for few seconds in the hue bridge, what actually happens? Is it resets completely? or only it erases mobile App data? What happens after reset?
