Hello,
As of late all of my Smartthings multipurpose sensors have an extreme delay ranging from 30 seconds to more then a minute (up to several minutes) delay going from closed to open and vise versa.
Is this a known issue?
Is there a fix that I can apply?
Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
Yes, email account registered in the forum is the same one I use for SmartThings.
Yes, support access to my account is now enable.
Multipurpose sensors affected are:
Balcony Door
Bedroom windows
Front Door
Front door sensor (added yesterday as an attempt to figure out what is happening)
Movie room window
Sport room window
Fridge door
Freezer door
Best regards,
//Peter
ps.
Other Smartthings devices are working normally. (Smartthings button, Smartthings motion sensor)
Hi,
I recently took my Smartthings hub of power and removed the battery backup and ethernet cable.
I left it so for a couple of minutes and then powered up the hub and as of now my Smartthings multipurpose sensors are not having any lagg.
When I, as of now, open a door the sensor is immediately indicating that the door is open in the Smartthings app.
I would be interested in knowing if you got any answers why my sensors start lagging as they did before?
Best regards and thank you for the great services.
