metadata {
definition (name: “Zigbee Hue White - HC”, namespace: “smartthings”, author: “SmartThings”) {
capability “Switch Level”
capability “Actuator”
capability “Switch”
capability “Configuration”
capability “Sensor”
capability “Refresh”
fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008", outClusters: "0019"
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
state "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 3, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
valueTile(“level”, “device.level”, inactiveLabel: false, decoration: “flat”) {
state “level”, label:‘${currentValue} %’, unit:“%”, backgroundColor:“#ffffff”
main “switch”
details([“switch”, “refresh”, “level”, “levelSliderControl”])
// Parse incoming device messages to generate events
log.info description
def msg = zigbee.parse(description)
if (description?.startsWith(“catchall:”)) {
log.trace msg
if(description?.endsWith(“0100”) ||description?.endsWith(“1001”)) {
def result = createEvent(name: “switch”, value: “on”)
log.debug “Parse returned ${result?.descriptionText}”
return result
if(description?.endsWith(“0000”) || description?.endsWith(“1000”)) {
def result = createEvent(name: “switch”, value: “off”)
return result
else {
def name = description?.startsWith(“on/off: “) ? “switch” : null
def value = name == “switch” ? (description?.endsWith(” 1”) ? “on” : “off”) : null
def result = createEvent(name: name, value: value)
return result
if (description?.startsWith(“read attr”)) {
Map descMap = (description - “read attr - “).split(”,”).inject([:]) { map, param ->
def nameAndValue = param.split(“:”)
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
log.debug "Desc Map: $descMap"
switch (descMap.cluster) {
case "0008":
log.debug description[-2..-1]
def i = Math.round(convertHexToInt(descMap.value) / 256 * 100 )
sendEvent( name: "level", value: i )
sendEvent( name: "switch.setLevel", value: i) //added to help subscribers
break
// Commands to device
def on() {
log.debug “on()”
sendEvent(name: “switch”, value: “on”)
“st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}”
def off() {
log.debug “off()”
sendEvent(name: “switch”, value: “off”)
“st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}”
def setLevel(value) {
log.trace “setLevel($value)”
def cmds =
if (value == 0) {
sendEvent(name: "switch", value: "off")
cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}"
else if (device.latestValue("switch") == "off") {
sendEvent(name: "switch", value: "on")
cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}"
sendEvent(name: "level", value: value)
def level = hexString(Math.round(value * 255/100))
cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 8 4 {${level} 1500}"
//log.debug cmds
cmds
def refresh() {
“st wattr 0x${device.deviceNetworkId} 0x0B 6 0”, “delay 200”,
“st wattr 0x${device.deviceNetworkId} 0x0B 8 0”
def configure() {
log.debug "binding to switch and level control cluster"
"zdo bind 0x${device.deviceNetworkId} 0x0B 1 6 {${device.zigbeeId}} {}", "delay 1000",
"zdo bind 0x${device.deviceNetworkId} 0x0B 1 8 {${device.zigbeeId}} {}", "delay 500",
//Switch Reporting
"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
"send 0x${device.deviceNetworkId} 0x0B 1", "delay 500",
//Level Control Reporting
"zcl global send-me-a-report 8 0 0x20 5 3600 {0010}", "delay 200",
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = “0” + s
s
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
