Event trigger info?
I have a Centralite smart plug that is turning on, seemingly spontaneously. I’m trying to find possible trigger events in the new IDE, but cannot. The only automation routine capable apps I have are Smartthings and Alexa, and in neither can I find a routine or scene etc that controls this plug.
Is it possible that Groovy was not completely dismantled, that some artifact exists out there that I cannot currently access but is nonetheless triggering device events?
Also, is there a better way to search the History than to scroll thru for many minutes? If you filter by device, you might miss the trigger device/event…,
might be that alexa auto assist feature (forget exactly what its called). one way to clear any possible ghosts would be to remove and re-add the plug.
