Newbie here. I mostly have lights hooked up and on/off control is fine, triggers are fine, but timed events to turn on/off seem to be running from UTC Time.
I thought the hub would know my local time based on location, zip, etc. Am I supposed to use the UTC Time to set these events?
The time should be using your local time. For me it is. Have you set your hub’s location? I have triggers set to go off at sunset and sunrise and works perfectly.
