Eurotronics Spirit TRV
Hi, please refer to my post about ScheduleTstatZones.…The smartapp can leverage all your ST connected temp/motion/contact/presence sensors and control your eTRVs in a smart way based on the concepts of rooms/zones/schedules.
You can download the code at my store
www.ecomatiqhomes.com/store
Regards.
Just pulled the trigger on 11 of these… I’ll let you know in a month or so how I get on :wink:
@mark_cockcroft or @dougalAgain is it possible for this device handler to be modified so that it can support the spirit’s direct valve control mode? I have an application in mind for these TRVs but would need to be able to set the valve to a percentage. Thanks!
yea it think so, you would have to look thourgh the manual on how to put it ito direct control, then find out the zwave command to send use
Hello,
right now I’m using Raspberry Pi + Razberry shell. I want to buy ST. Right now I’m using 11pcs of eurotronic spirit trvs. I can see that it will work with ST (thanks to some people here) but can I set easly schedule with ST and Eurotronics? And for eg. can I set downstair one temp. via one button? Can someone put here some printscreen with app solution?
HI there,
I just bought Spirit ZigBee TRV’s from Eurotronic - and i’m wondering is that TRV works with SmartThings.
I want to choose z-wave / zigbee hub to my home and Smartthings looks very interesting.
Doe’s someone integrated those TRV’s with Smartthings ?
Regards ,
Greg
This looks the same
Released today I believe
No smartthing lol! mabe no one wants to commit to ST
Just got an email from Aeotec mentioning this…they do look identical…I wonder if they are the same under the hood, and if we can expect a native handler that will work with the Eurotronic Spirit too?
@philt & @mark_cockcroft
I believe Eurotronics is a german company and they say this
Is any TRV supported on ST?
@dougalAgain. I downloaded your DH code from Github, however my new Eurotronics spirit is not found at inclusion, nothing visible at inclusion in the log.
I am adding as other z-wave device.
I only have had zigbees so far.
Any tips what could be wrong? I had this problem with zigbee begore, if dth is not installed its not recognizing. Have the changed productid? Is it a broken unit? Shall I send it back? Can I capture communication on raw level somoehow?
same behavior with me. I had them working on the v2 hub and changed now to the v3 hub.
I can see the channel number on the device while I make the inclusion - but it does not appear on the app as a found device.
seems to me that the hub has a problem in communicating with the device??
I’m really new to ST and want to move from my current ZWave controller to the ST Hub v3. I currently use several Eurotronic Spirit TRVs (EU) and tried to use the DH from @dougalAgain and also the one from @mark_cockcroft.
They DH show up, but look completely different then shown in the screenshots in this threads (which I really like!). I’m also not able to set any mode or turn the TRV on or off.
I think I do something wrong as I see posts where the DH are used with success.
Can anyone help me?
You need to use the classic app and also can’t use the latest version as it’s broken install 2.17.0
Thanks for this hint!
With the classic app this works. Only the pretty icons shown above doesn’t appear. But the TRV can be controlled.
But I used the latest version of the classic app to try this which is currently 2.18.1.
@rockberte, Change to 2.17.0 from Apk mirror and it will show the icons correctly.
The new app does it’s own thing and in the classic app all the icons are broken.
@smartthings are you going to fix classic? @bradst, would you know?
Samsung broke it there is nothing we can do other than using 2.17.0
Hello I use eurotronic spirit zwave, can I upgrade the firmware??
thanks.
