Eufy doorbell
Anyone know if there is a way to integrate the Eufy doorbell with Smartthings?
Nothing direct. :disappointed_relieved:
You can use an Alexa routine as an intermediary and get partial integration, at least you can do something when the doorbell is pressed.
Thanks, I’ve been using a virtual device to trigger different things. Just wondered if anyone had moved things further forward.
This could also probably be done if you have an Android device running Tasker already and add this plugin:
I do it where my Android reacts to Eufy notifications then sends HTTP requests to my Hubitat. With the plugin above, it should be easier to SmartThings. I haven’t used that plugin lately. No idea how it works to know if it will still work with the new app.
The Alexa route is probably simpler though. With my method and Hubitat, its local after receiving notification but that’s obviously not case with ST so might as well use Alexa.
Yes, the SharpTools plugins still work with the new app.
