EspEasy-Connector
Hello all,
i have a problem with the EspEasy-Connector.
I have intigrated the ESP Connector according to the instructions on Github. In the Smartthings app I added the ESPEasy temperature sensor. Unfortunately it does not show any temperature. Under history I can see the temperature.
app issue most likely…
The broken cloud icon is often an indication that an attribute has a null value. As temperature and relative humidity share a tile it is likely that it needs a humidity value before the temperature is displayed.
If the device handler is a few years old it will predate the app’s requirement for attributes to have valid non-null values.
The app has recently been broken in other ways that can cause similar symptoms, but the EspEasy-Connector sounds like it has been around for a while which is why I suggested the above.
