Error when saving or creating smartapps?
I’ve been having difficulty making changes to my smartapps. Whenever I click save, or try to import updated code via github, I get the following error in the IDE:
groovy.lang.MissingPropertyException: No such property: id for class: java.lang.String
Any idea what I could be doing wrong?
It’s not giving you a line number for the error?
Post a link to the code…
I get that error even if I try to create the sample app…
I tried copy/pasting the IFTTT app in, and I get the same error.
Ah, I did some binary-search code copy/paste, weirdly enough, I had a description block like:
definition( name: "Soy dev SmartThings", namespace: "hfwang", author: "Hsiu-Fan Wang", description: "Exposes a smartthings hub to the vagries of soy chat.", category: "", iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png", iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png", iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
Note the empty string in category. I put in one of the other categories (I used “SmartThings Internal”), and then everything worked fine.
For me, the issue was that when I created the sample app and selected “Safety & Security”, it auto-generated “Safety & Security” in the code. Apparently what this error really means is that the Category isn’t an exact match for one of their pre-defined categories. I changed it to “Safety & Security” in the code and it saves now.
BTW, this happened with a new app, no changes to the core auto-generated code.
There’s an error currently when the category has an “&” in it. As a workaround, if you look at the generated SmartApp code, you can remove the amp; then it should work.
So for example, change category: "Safety & Security" to category: "Safety & Security".
