Had to delete it as after changing battery it won’t update but now when trying to add this comes up in log and hub doesn’t find it.
org.springframework.orm.hibernate3.HibernateOptimisticLockingFailureException: Object of class [physicalgraph.app.EventSubscription] with identifier [00df6b98-ed7b-4a8a-812c-9c48c65e3603]: optimistic locking failed; nested exception is org.hibernate.StaleObjectStateException: Row was updated or deleted by another transaction (or unsaved-value mapping was incorrect): [physicalgraph.app.EventSubscription#00df6b98-ed7b-4a8a-812c-9c48c65e3603] @line -1 (doCall)
If you have any custom device handlers, you may want to open them and publish for me again. Then try to add your sensor.
Added it after trying multiple times and pretty much had to put it on the hub but now it won’t change temperature values unless I press Refresh in the app!! How often does it report temperature?
