I am just getting started and trying to install a device handler for a monoprice z-wave plus multi sensor. I copied the code and then get this message when I click Create:
No signature of method: script_app_metadata_b266a064_b427_4a29_8e55_932fd26dc287.metadata() is applicable for argument types: (script_app_metadata_b266a064_b427_4a29_8e55_932fd26dc287$_run_closure1) values: [script_app_metadata_b266a064_b427_4a29_8e55_932fd26dc287$_run_closure1@7ba51280] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)re)
bamarayne
#2
Make sure you are installing the device handler code in the device handler section, not the smartapp section.
Thanks, that was the problem. I was able to install it as a device handler but still not sure how to link it to the device in my SmartThings app. I see the device with only a option for SmartApps.
You can change which device handler a device uses from the IDE. This topic is a good overview. The step I’m referring to is in Section II of this post after it talks about SmartApps.
