I have a moisture sensor (1 of several around the house) that has an event log entry captured titled “ENTITY_UPDATE” :
Has anyone seen that before? If so, what the heck does that mean? I’m using ST’s default device type “SmartSense Moisture Sensor”, so maybe they pushed a change?
The reason I’m asking is because I woke up to no water this morning, and discovered my water valve was shut off because this leak sensor sent the command to close it at the same time that event log entry took place, and I can assure you I did not have a leak.
Damn poltergeists…
