Just random routing stuff - looked all nominal
There must be a couple of revisions. The doc that came with my devices talked about a āredā light and there is none. It also talked about a test mode for motion and there is no way to get into the test mode.
Iām not going to let this thing win. I will conquer it.
@wackware
Just pinging the thread here. Finally got a chance to try these again after itās been stuck to the ceiling as a door/window contact sensor.
Did we figure out how to get it to properly report as a motion sensor?
Saw in amazon the following review
Verified Purchase
Works great with Smartthings. BUT after you add it to your network it will think its a open/close sensor. You must go into graphs and change the type of device it is. After that it works perfectly. Google search āsmartthings graphsā if you donāt know what Iām talking about.
No clue if those that have it have tested changing the device type and seeing how it behaves
According to the ST device code, which I just recently opened up for a generic āZ-Wave Motion Sensorā ā support for this device exists. However, the comments allude to a fact that pairing the device doesnāt always go so smoothly. Maybe thatās the root of my problem.
Hi everyone, sorry for not posting anything here for a while. In working with Duncan, it looks like the device is real goofy during the pairing process. Sometimes it may work, sometimes not. It actually might have a better chance farther away from the hub. But,once paired itās good to go.
Meanwhile, I am waiting to hear back from the device mfg/support folks. We need to get it to be more robust during pairing.
Just a thought. When a device is paired with ST, doesnāt configure() get run?
If the device type sents the wrong parameters to the the device, could the configuration of the device get screwed up?
I would suggest trying to do a factory reset of the device.
The problem is in the pairing process itself. It does finish pairing correctly.
I wish I had read this thread before I bought mineā¦ I canāt get the thing to pair AT ALL. At least you guys are getting it to show up as something. I put fresh batteries in, press the black button, light goes on for at most a second and then just flashes when it detects motion. Hub discovers nothing. Iāve tried adding it as a door sensor, as a motion sensor, just āconnect new deviceā Iāve tried it next to the hub, across my house, and in between. Iām ready to smash it with a hammer. How did you guys add it in?
I can get it to add, once, and then thatās it. I canāt figure out how to exclude it properly and then readd it.
Iāve also noticed (I have a stack of about 10 of these), that if you set it up and move it, the routing breaks and the thing is useless again.
Pulling the batteries doesnāt seem to hard reset it. If you can figure out how to factory reset it, please do tell
It sounds like it thinks itās already paired. Does it blink 3 times after quickly pressing button?
This random one I just picked up goes solid green for about 2 seconds.
http://enerlites.com/media/mconnect_uploadfiles/z/w/zwn-bpc_3.28.pdf
According to the documentation, that suggests its still paired to a network. ST canāt see it, so my gut says to exclude it. Iāve never gotten that to work with this device correctly.
Yep, put St hub in exclusion mode. Then tap the button on pir. It usually happens right away.
I just tried this and nothing. Still blinks solid once. If it had been paired with somebody elseās network before mine, would I be able to reset it?
Same thing for me. Canāt get it to exclude or include
The exclude mode does not need original paired hub. How long are you holding the button down on pir? Just tap it for a second or less. Same for paring. Holding down for more than a second is for programming mode which different.
These are very hit and miss for paring. Some might, most wonāt. Iām still waiting on OEM to get this fixed.
So interestingly enough, it seems that I canāt include / exclude anything right now. I just tried a bunch of devices that are usually no brainers (RS100HC) ā and I didnāt even get anything in the log. I wonder if we have an outage right nowā¦
So that was at least part of the issue. Sending the ārebootā command to the hub wasnāt doing anything. After cold rebooting it on the APC, now I can include / exclude again. Trying the PIR now
PIR working great now. I hate how I spent days on this ā¦ and all I needed was a reboot on ST. Brutal
Edit: Just in case anyone else stumbles on this, Iāve had to cold reboot my hub on every inclusion / exclusion of this model of PIR. The logs donāt reveal anything obvious as to why this is.
Just curious about the pir, how far from the hub were you when you paired it?
