I recently replace a GE ZWave switch with an Enerwave ZWN-500D. I also replaced the GE aux switches (2) with the Enerwave aux switches. These switches controlled 8 LED ceiling lights (about 20W each).
I replaced the GE switch because manually turning it on did not always work (I could always turn it on with the app). The Enerwave requires a neutral wire and is supposed to work great with LED’s.
The switch works great, turns on/off manually just fine and with the app. The problem is that when I come downstairs in the morning all 8 lights are usually on (this happens 2 out of 3 mornings). Looking at the activity history they were turned on between 11 PM and midnight. The log shows ‘physical’ but no one is near the switch at these times. I have not yet connected the switch to any SmartApps.
Could this be a defective switch?
Any other ideas, ie should I remove from network and re/add?
Thanks,
Chris
