Endpoint null is blacklisted
Hello SmartPeople
I’m developing a SmartApp for HoneyWells Total Connect integration here and I have seem to have hit road block on a key process that I would like this app to have.
I always get the message
error java.lang.SecurityException: Endpoint null is blacklisted. @ line 69
and line 69 is httpPost call below. I don’t understand why is this backlisted. All the other API call in this App are executed in similar manner. Any pointers?
By the way, this is basically doing this call - https://rs.alarmnet.com/tc21api/tc2.asmx?op=GetZonesListInState
       def getZonesListInState = [
		uri: "https://rs.alarmnet.com/TC21API/TC2.asmx/GetZonesListInState",
		body: [ SessionID: token, LocationID: locationID, PartitionID: 1, ListIdentifierID: 1]
		httpPost(getZoneListInState) { responseZoneListInState ->
							 log.debug responseZoneListInState.data
normally when i see error java.lang.SecurityException: Endpoint null is blacklisted there is a url in the error, in your case you have null. sounds like something (URL) is not being passed correctly.
try splitting uri and path…
url: “https://rs.alarmnet.com”,
path: “/TC21API/TC2.asmx/GetZonesListInState”,
You also might want to set the content type or do a httpPostJson() if it’s a json post.
Thanks for all your suggestions guys.
I tried splitting the URI & PATH (below), still no dice. Im doing everything to replicate the HTTP Post call listed here - https://rs.alarmnet.com/TC21API/TC2.asmx?op=GetZonesListInState, but still I end up getting endpoint “null” backlisted. Open for other suggestions. Thanks
		uri: "https://rs.alarmnet.com",
        path: "/TC21API/TC2.asmx/GetZonesListInState",
        contentType: "application/x-www-form-urlencoded",
		body: [ SessionID: token, LocationID: b.locationId, PartitionID: 1, ListIdentifierID: 1]
Looks like you have a typo.
Variable name is getZonesListInState
Passed variable name is getZoneListInState (note the missing z in Zones)
Holy c**. Im going to beat my self if this works now
Let me know if this fixes it.
We’ve all been there. I’ve had at least two of these kinds of issues in the just the last week.
That works.
[quote=“Dianoga, post:6, topic:21376”]
[/quote]This is why we can’t have nice things. Or rather this is why you want a real language, or at least a complier that warns you helpfully “variable so and so used without being set” - because static code analysis could tell you this :wink:
Sorry I missed the more obvious bug too.
So you got this working? Every time I try to make this call I get
groovyx.net.http.HttpResponseException: Internal Server Error @ line 137
Did they change something since August?
I think I virtually stole your code. I really want to be able to read the status of a few of my zones, so I can do things like check if the alarm door sensor is closed before attempting to lock the door.
Map panelZonesList(token, locationId) {
uri: “https://rs.alarmnet.com/TC21API/TC2.asmx/GetZonesListInState”,
httpPost(getZonesListInState) { responseZoneListInState ->
