Other LAN Edge drivers have reported issues with the new hub update (0.54.10).
The culprit appears to be the getpeername() function which I can confirm is being called in the watch_socket function (line 188) of the LAN Motion Driver.
It appears @TAustin isn’t actively monitoring these threads but is there someone on the Dev Team (@nayelyz can you help?) that knows why this call to getpeername() appears to cause things to “blow up” since the 0.54.10 hub update?
Hi, @Puzzling
I already opened a report for the engineering team as they mentioned this required further investigation, so, once I get more info, I’ll let you know.
Hi, everyone!
The engineering team announced this release to fix the issue with the function of getpeername(), once it’s rolled out, please check if the devices start working again, if not, open the logcat using the CLI and see if an error starting with “caused by: Watchdog error” appears:
For this, you need to set up the ST CLI and run the command below:
smartthings edge:drivers:logcat
The CLI will prompt you to select from which hub and driver you want to listen to events
Then, try to send commands to the device and see what’s registered there.
Howdy, everyone: While looking for a solution to check when non-UPnP-compliant devices are online, I came across TAustin’s Ping Tracker Python script, which runs alongside EdgeBridge in his test channel. I noticed a bug in the Ping Tracker’s code and wanted to mention it here since I didn’t find a dedicated thread for it.
My change hasn’t been fully tested yet, but so far, everything seems to be working. The issue I encountered was with ICMP responses randomly returning Type 3 (Destination Unreachable) messages, likely due to other configuration issues on my network that I’ll need to address. The script incorrectly marked these devices as online when receiving a Destination Unreachable message. My update adds a logic statement to disregard any ICMP Type 3 error messages and unknown responses outside of a successful ping.
I haven’t shared a script online before, so I’m not sure what the best approach is. Should I submit it to GitHub or share it here in the thread? Thanks much!
Todd is no longer actively contributing to this community. If his repo is public, I would suggest forking it and publishing an update either in this topic or establishing a new topic related to the issue.
Thanks for the info, my good sir. The repo is indeed public, so I’ll start a new topic after sitting on my updated script for a bit to confirm the functionality.
