It totally depends on how critical it is that you have the current value in SmartThings. I wouldn’t go any lower than 10 seconds ordinarily, but every 60 seconds is probably sufficient for most purposes.
You can also tap the Refresh button at any time to get the latest values.
If things aren’t working correctly, you’ll need to get the CLI and run some logs so I can see what might be happening. If you need some help with that, just direct message me and I’ll guide you through it.
Hi. Add.on with a Ds18b20 sensor connected. I need it to retrieve the exact same info displayed in the Shelly app,which is the actual temperature and the average at each hour. That specific part, the comunication at each hour, is keen for my automations.
If anyone besides @Bruno_Almeida has a Gen2 Plus 1, Plus 1PM, or Plus 2PM with an add-on, can you please do me a favor and enter this in your browser address bar?:
http://<ip_address>/rpc/Shelly.GetConfig
where <ip_address> is the IP address of your Shelly device.
Please direct message me with the results. Thank you!
@TAustin
Hello, Sorry for the delay again in responding.
I would like to thank you for your attention as I managed to make it work. At least so far everything seems to be correct.
It was a configuration error on my part, but in the end everything worked out fine.
Thank you very much for your help time.
I have pushed out an update to the Shelly Gen2 Device Driver V1.3, which is now driver Version 2023-04-13T15:15:51.357935579.
This update includes temperature (ds18b20) and digital/analog inputadd-on support for the Plus1 and Plus1PM devices. Add-ons are detected during device discovery, so no manual device Settings are needed. If you connect one of these add-ons for an existing SmartThings device, you’ll need to delete the existing device and get it recreated through an Add device / Scan for nearby devices.
Please note that if add-on support is needed for the humidity or voltmeter attachments, or add-on support is needed for other device types (i.e. Plus2PM, PlusI4) I can add that upon request.
One other update item is that the Creator device will no longer get created for initial driver installations, and the IP address in device Settings should be ignored (it has already been removed for some devices). There is no manual creation of GEN2 devices - they are discovered and created automatically. With this driver update, you can delete any existing Creator device you may already have and it will not get re-created the next time you scan for devices.
I do want to call out one thing I have noticed so this group is aware. I am using 2 Shelly PM 1 Plus devices with an addon for one of the PM’s with Reed Switches attached to the 3 interfaces. I also have the Alexa Smartthings skill enabled as well as the Honeywell Alexa Skill enabled for my thermostats (2 of them) so I can control devices with Alexa.
When I ask “Alexa what is the Inside temperature” it averages my 2 thermostats and the 2 Shelly PM 1 Temperatures to provide an answer. This is because Shelly has internal temperature monitoring in the PM 1 Plus devices that it must send over to Alexa. I see no way to turn this off with the exception of disabling the Shelly’s in Alexa, which I can do because I use virtual switches to control opening and closing of my Garage doors which because it gives me better overall control.
Just though I would call this out to make everyone aware. Maybe @TAustin could provide the ability to configure whether or not include the devices internal temperature in the Smartthing update payload!
The only reason I can see using the internal device temp is to determine if the device is overheating since it is not the actual temperature of the space the device is in. I would be curious to see what others think about how you might use the internal temperature on a PM 1 Plus. I do understand that if you hook up an actual temperature sensor to the device that you would want to have the temperature.
To me that internal temperature info is just annoying because it is the first temperature displayed instead of the temperature provided by the sensor on the addon.
I just wanted to say thank you to @TAustin for developing this driver. The driver provided by Shelly did not seem to include the ability to read the switch input state, but your driver seems to work like a charm. Now I can get reminders if my garage door is left open .
For anyone else appreciating this driver. You can support him here.
For the GEN2 devices, how would everyone feel about the possibility of moving the device’s internal temperature measurement down to the ‘Devices’ component?
Does anyone actually use this value in any automations?
Is it a nuisance to have it where it currently is in the device Controls screen?
I would have no concerns. Would it also fix the issue I have with the internal temperature being shared with Echo (Alexa) if I have the device enabled there causing it to be included in the average “Inside Temperature” calculation when asking Alexa for the “Inside Temperature”?
I don’t recall if Alexa would recognize any capabilities not in the ‘main’ (first) component, which is where the internal temp is now. If I move it to another component like I’m thinking, it may become inaccessible to Alexa. Not positive, but will confirm.
That link is years old and I did not find a list there?
I did add in that Faq that I use the Smartthings/Aeotec Water Leak Sensor to interface a dry n/o contact from my rain sensor.
