The VIRTUAL devices in general seem to be useful where the capabilities have setter or enum commands. However without those they seem to rely on an automation setting their events directly. The custom devices have the option for ‘command mappings’ but it isn’t clear exactly what they actually they are meant to do as they seem to apply to capabilities but are added at the device level.
Local execution seems to be allowed for. My best guess is that this provides the mechanism for creating virtual devices in Edge, with the Virtual Switch driver being an example.
I would imagine there is some kind of app handling the cloud based virtual devices, however when it comes to local ones I would argue that there is something to what I am saying …
Hi, @lmullineux. Thank you so much for your contributions, about this, more information about virtual devices will be shared later on.
This option is available in the CLI as @lmullineux mentioned, the team knows there are still questions about how those devices work so, that’s why they’re collecting more info about them.
If it’s to figure out between current and old, You could look at the health value to see when it was last seen, also you can look at the current state to see if it’s present.
I have some issues after pairing Aqara devices with Edge drivers, battery not shown and next day OFFLINE. I had similar issues with DTH for Aqara, this happens every time when the device is not paired directly, but through routing with another Zigbee device.
In IDE, only placeholder is shown on drivers. I tried using your tool but I can’t seem to find Route. Is this something I can see somehow here?
I have an Aqara door sensor I’ve used for a while. I recently replaced my modem and router, and the sensor wouldn’t connect. I deleted the sensor from my devices on smartthings, but when I added it back it continued to show as a switch instead of a sensor. I changed the type to the Xiaomi Aqara Door/Window Sensor, and then it asked for a device network id. I used your tool to find that but still no luck. Lastly, when I select my hub from the dropdown it says access denied.
I’m still new at these things sorry if I didn’t explain things properly. Any help would be appreciated.
You are more likely to find an answer if you post on a thread for your device or driver. Or post a new thread. It will be more likely to be seen by people with the knowledge of your device who can help.
Is there a way to see the device fingerprint using this? I clicked through all the options and couldn’t find. And for things on edge drivers I cannot see in IDE.
Thank you and TAustin for your awesome work on these API tools… Do you know if the device firmware information is available through API and if so, can that be added to the device info or health section?
I know in the IDE its in the raw device description. Maybe I’m not looking in the right place in your tool.
Firmware info is available for devices that support it, just click the clipboard next to a device on ‘simple device viewer’ , then look for the firmwareUpdate object
