[EDGE] Official Monoprice Plugin Power Monitor Driver
RBOY APPS is now an official partner of Monoprice.
This Edge Driver is for the Monoprice Plug In Power Monitor (15903).
This Plug In Power Monitor can be operated remotely or directly, using the Switch on the device. It plugs into a standard NEMA 5-15 power outlet and includes both a Z-Wave controlled outlet and standard, unswitched outlet. It is designed so that when it is plugged into a standard two-plug wall outlet, it will not block the other power socket. In addition to controlled switching, it monitors energy consumption and can report consumption values in several common energy scales. As an AC powered Z-Wave device, this Plugin will act as a Z-Wave repeater (supporting FLiRS).
This driver supports the Z-Wave and Z-Wave Plus devices. Support has also been added for v1 and v2 hub fingerprinting for easy identification. Ideally install the Driver BEFORE pairing the device for easy setup.
Old App
Classic App
The Plug In Power Monitor can be bought directly from Monoprice here for about $31 - $34
We’ve worked with Monoprice create a special deal just for the SmartThings community:
15% of all Monoprice products with RBoy Apps Device Drivers
  1. Click here to visit the Monoprice website
  2. Use the code RBOY at checkout
  3. Monoprice offers FREE standard shipping in the US.
Enjoy, this code expires Dec 31. This is a stacked promotion code, i.e. it can be used in addition to with other discounts/deals from Monoprice
This device driver supports the following features:
  1. Reading the following sensors
    • Switch on/off
    • Voltage (V)
    • Amerage (A)
    • Power Consumption (W)
    • Energy Consumption (KWh and KVAh)
    • Power Factor (pf)
  2. Designed UI using the latest ST multiTiles with a clean view
  3. Ability to configure the following parameters:
    • Reporting thresholds
  4. Supports routines and automations
  5. Ability to request a manual update for the sensors and configuration
  6. Easy to use configuration page with detailed explanations for all the parameters
Ideally install the Device Driver BEFORE pairing the device for easy setup.
More features to added, if you have any suggestions or ideas please feel free to ask and we’ll try to add it.
NOTE
  • The color of the LED depends upon how much power is being drawn by the connected appliance:
    • Green → 0A to 5A
    • Orange → 5A to 10A
    • Red → 10A to 15A
INCLUSION INSTRUCTIONS: It is recommended to install the Device Driver BEFORE paring the device for easier setup.
  1. Bring device within 5 of hub
  2. To pair the device, Select Add New Device on your ST phone app
  3. Plug in the device into the wall socket, the light should be flashing red/green
  4. If the light is solid then you need to exclude it first (see below)
  5. Press the power switch atleast 3 times within 2 seconds, this should start the pairing process
  6. It should complete pairing within 30 seconds
NOTE: It is usually a good idea to do a Z-Wave repair after pairing a new device
EXCLUSION INSTRUCTIONS: If you deleted the device without excluding it won’t pair up again until you exclude it.
  1. Set the hub into exclude mode (log into the IDE → My Hub → View Utilities → Z-Wave Exclude.
  2. Bring device within 5 ft of hub
  3. Put hub into exclusion mode
  4. Press the power button for 1 second and leave it. Alternatively press the power button slowly 5 times in 5 seconds
  5. When the exclusion is successful the light start flashing
FACTORY RESET: Plug in the device and press and hold the switch for 5 seconds.
Check out these other SmartApps
[RELEASE] Door Chimes and Notifications for Doorbells and Sensors
[RELEASE] Security System: Intruder Alert with Actions
This device driver is available on the RBOY APPS Server. Refer to our website or facebook page below to get access to the server.
Visit our Facebook page for updates on new apps and to get Access to ALL our Premium Apps and Server. http://www.facebook.com/RBoySTApps
Labor Day Sale Alert: Folks, Monoprice has a 5% off sale running here and if you combine it with the RBoy Apps 15% you can buy this device for under $28.
Official Monoprice Plugin Power Monitor Device Handler - Version 01.00.01
  • Added support to show numbers with 1 decimal place for better accuracy
Cab this handler be used to send notifications? Looking for washing machine status notifications. Thanks.
Only SmartApps can send notifications, device handler can report events to SmartApps. What you can do is use a SmartApp like CoRE or WebCoRE and create a rule to notify you when the device handler sends an event that’s above or below a threshold (like power consumption or amps etc)
Official Monoprice Plugin Power Monitor Device Handler - Version 02.00.00
  • Support for new ST app custom controls
NOTE: It may have 48 hours for the platform cache to update the UI, it helps to switch the DTH, sign out of the ST mobile app and then sign back in to force a refresh. As last resort, you may need to exclude your device, delete the device handler and re install it for the changes to take effect.
Official Monoprice Plugin Power Monitor Device Handler - Version 20251121
  • Edge driver for new ST hubs
  • Support for routines and automations
Official Monoprice Plugin Power Monitor Device Handler - Version 20260106
  • (Fix) Support for new hub firmware
