[Edge Drivers] Sonos Devices - Behavior After Migration
For what it’s worth, I’ve long used the node-sonos-http-api for audio notifications over Sonos, as it allows greater control over the voices, volume, speaker selection, and more. It’s also easy to integrate notifications into routines and rules when paired with TAustin’s ST Edge Web Requestor .
Just another option to add to your list.
@nayelz
By DM, I’m sending a driver log that shows the large backlog of events that flood SmartThings when the driver transitions from being non-responsive to responsive. Hopefully this will prove useful somehow.
@nayelyz has any progress been made on this issue?
Same issue with 8 sonos connect amps. Everything stops working that has been working great for years. You then have to get Alexa to play sporify on one of the amps and then you get the backlog of all the smarthings messages coming through. This is crap quality controll and wasted days of my time. Please smarthings get your act together and get this fixed.
unhappy customer. How can you possibly break something so badly!
Copied from the other SONOS Beta thread, didn’t know this one was more uptodate
Now the SONOS is driver is out of Beta, it seems very flakey.
I’m running SONOS V1 with some older devices like 1s,3s,AMP and Connect plus newer ones like PLAYBASE,PLAY ONE and MOVE.
Operating grouped devices with pause/play from one device through ST is not very reliable…I’ve had to remove and readd devices to make it work, after either no pause operation visible or server error msgs when trying to pause…Anyone else experiencing issues…
Plus something else has changed which stops ACTIONTILES from seeing SONOS devices (Alex is looking into the problem)
An update to my situation (see my post above).
  • I split my Sonos now into a S2 and a S1 system which is an annoying compromise, but the speakers in the S1 system were rarely grouped with the ones in the S2 system anyway, and I can live with the notifications only being on the S2 speakers.
  • Before I split the system I actually had some success of getting some Sonos functionality working (but I want notifications via S2). I did try a lot of things, and not sure it it was just a coincident but my speakers all had Danish special characters in their name. I had problems with smart home stuff before with Danish characters. If some API etc. have dodgy character handling, character encoding/decoding via transport etc… (and sunshine Dev/QA testing not trying out cases like this). So after giving them purely English names with no special chars it seemed like they finally were quickly discovered by auto scan (before it was a hit and miss using direct brand search), but it might just have been some other change I did. I can also see on my.smartthings.com/advanced that there was a driver update on 18th, think that was around the time of my fiddling so could be why also.
  • Now it works better with notifications, and I restored my mapping of buttons on some z-wave devices I have to Sonos functionality via Sharptools (was also very strange getting working, took an hour of trying disconnecting/re-auth between SmartThings/SharpTools before I could see events in logs). I haven’t tested it that much though, as being busy with other stuff.
  • I also did get notifications working with Google Home by using a Virtual Switch (TAustins edge drivers), but I prefer the notifications on the Sonos speakers.
Feel free to tag me if you have questions specific to SharpTools. Or you can always email support@sharptools.io and we can take a closer look if things aren’t working as expected. Keep in mind that if a device was re-onboarded to SmartThings, it will have a completely new device ID, so you’ll want to make sure to update your SharpTools rule triggers (which cache the device name) to point to the new device after reauthorizing.
As many of you have noted, unfortunately the new Sonos Edge Drivers have had some pretty fundamental issues though. :grimacing:
@Nezmo and @bthrock are also power users and great at troubleshooting and providing relevant details, so hopefully with @nayelyz on the case, we’ll start to see some progress and resolution of the core Sonos issues. :pray:
Nice work.
I would, however, caution you to remember that the current Sonos integration with SmartThings is, at best, unreliable. It will stop working, unpredictably and without notice. (My system has done so twice already today for hours-long stretches.) There are ways to reawaken the websocket connection, but that is a temporary fix only and defeats the purpose.
SmartThings is very much aware of the issue, but typically doesn’t post progress reports until there is actual progress to report. I’m hopeful we’ll get an update in the very near future.
Stereo pair and surround group both gone offline in ST this evening and so far refusing to come back online in ST. Full reboots from devices up failed so far, no obvious trigger…
@nayelyz hub logs dumped.
Anything you can share @nayelyz? This one is kind of a big deal.
Surround group and speaker pair remain off-line so leaving alone for the time being. Do not want to power cycle hub more than is strictly necessary now that soft reboot option is removed.
I should emphasise this is only an issue in ST, Ikea and Sonos itself have no issues… also no problems with 7 other Sonos (single non-paired) units.
I’ve had another case of the app not updating or controlling Sonos after 2 weeks running OK since a Hub re-boot.
In this case it might have coincided with the Sonos performing a firmware update (15.6).
It wasn’t apparent right away because scenes started from routines were still running OK - only direct Sonos control and history in the app were affected.
In this case running a scene including Sonos from the app also still worked and actually unfroze app control - so no Hub reboot was required - but events over the last day didn’t show up in the app.
Right! Because these failures can and do occur entirely in the background while the system itself is running fine, I don’t think most users have any idea how often they are happening. I’ve been tracking them through an external automation that compares events reported by the UPnP interface against those reported by SmartThings and, in my case, with a system that runs almost non-stop, I see them occurring almost every day and in some instances multiple times a day. Users will often not be aware of this because other events, such as pushing a command through the system outside of SmartThings, as you did, frequently “reawakens” the SmartThings connection.
@Nezmo said, this is “kind of a big deal.” I disagree only with the “kind of” part.
Same here. At first I thought it was just Track and Album Art not working with Stations. Then everything stopped working (pause/play, volume, etc.). All fine through the Sonos app, Spotify, or Lutron pico. Rebooted the hub and controls work again but not Track and Album Art with Stations.
Contacted Customer Support but no feedback. Would be nice to know if someone is working on this.
I wasnt describing some background glitch cleared by “pushing a command through the system outside of SmartThings”
The app control of Sonos was frozen for a day but not scene control triggered by routines - so things did appear to be working OK until opening the app and noticing the Sonos device was showing as stopped when playing.
The unfreeze was to run a scene including Sonos from the app - not something external.
These are somewhat different behaviours to mentioned before plus I think the freeze start might have correlated to Sonos performing a firmware update - which if repeatable ought to help a fix.
My apologies. I read your post too quickly and thought you had initiated something from the Sonos app, not SmartThings. That is clearly not what you said.
To be clear, however, no one here is talking about a ‘background glitch.’ We’re all describing the same basic issue—the app failing to report events, which causes a variety of problems, the most apparent one being the app failing to display the device’s status and history accurately. The other side of that coin is that commands sent to the API are often either not executed at all or executed on a very delayed basis.
I’m a little surprised that executing a SmartThings scene via any means would awaken the websocket, because that’s just another API call. But I don’t discount it at all, either, as people have reported having success reawakening the integration in a variety of ways. Sometimes it restarts without outside intervention.
But thank you for correcting my mistake. You’ve given me another path to test.
Many might have their Sonos set to auto-update f/w but I knew when I’d run the update from inside the Sonos app - it was a little after the last event recorded for the Sonos device in the app before it froze. Maybe a coincidence but I’d had no other freezes for two weeks.
As routines->scene->Sonos were still working I tried running the scene from the app and not only did it work but returning to Sonos device in the app it had unfrozen without a hub restart - Sonos events while frozen were still missing though.
@nayelyz can you let the community know if this is being looked at?
Hi @nayelyz , I echo the plea for an update - as of this morning ALL my Sonos devices have now dropped off line in ST and show no signs of being rediscovered!!
Logs dumped again but no idea when devices dropped off line except to say between 22:00 27th and 12:00 28th UK. You already have hub access (till the 15th).
Thanks, :slightly_frowning_face::slightly_frowning_face:
Hi, I was talking with the corresponding team and they are still actively investigating and working on this case.
@TheHundredthIdiot I will share this information with the team :saluting_face:
