[Edge Driver] Tuya Zigbee RF Cloner / RF Blaster (TS0601, 8 slots) – learn & transmit 433MHz remotes
Hi all,
I built an Edge driver for the Tuya Zigbee RF Copier / Cloner (ZRF01, with illuminance sensor). It learns fixed-code RF remotes (fans, lights, curtains, gates, sockets) into 8 slots and transmits them from SmartThings.
FEATURES
  • 8 slots – Learn / Transmit / Delete per slot (custom capability, one component per slot)
  • Learn from the device card or from Settings (Button 1-8 Action)
  • Optional child devices “RF Slot 1-8” (setting “Create slot buttons”): a switch tile per slot on the dashboard, usable in routines and renameable. Turning the setting off deletes them
  • Illuminance reading
  • Packet mode setting (short / long)
SUPPORTED FINGERPRINTS
  • TS0601 / _TZE284_tdg4ckyh
  • TS0601 / _TZE28C1000000_tdg4ckyh
    If yours reports a different manufacturer, post it here and I’ll add it.
HOW TO LEARN
  1. Tap Learn on a slot – the LED turns red
  2. Touch the remote to the cloner and HOLD the button 2-3 seconds
  3. LED turns blue and the slot shows Saved (can take up to ~30 s)
KNOWN ISSUES / TIPS
  • LED stuck on red: Delete that slot and try again (or toggle the main switch)
  • Learning sometimes fails on the first try – hold the button longer and retry
  • Fixed-code remotes only. Rolling-code remotes (most modern gates/cars) will not work
  • If the hub runtime gets stuck, a hub reboot fixes it
  • Long Packet mode is not tested yet
  • Tested on one real device (fan remote, all 8 slots, incl. hub reboot)
INSTALL
Channel invite: SmartThings. Add a little smartness to your things.
Enroll, then install “rf-cloner-8ch” on your hub and add/switch the device to it.
Device (AliExpress): https://s.click.aliexpress.com/e/_c3FXyxZh
Many thanks to @gilrose1 for the extensive testing!
Free to use. If you like my work: https://buymeacoffee.com/dotan_shai
Feedback welcome, especially on other manufacturers/remotes.
Dashboard screenshot with child buttons
Settings screenshots
Details screenshots
